Roller Stator Shaft Dimentions
   / Roller Stator Shaft Dimentions #1
blake in spokane
Trying to identify tapered shaft dimentions - Rollor Stator hyd. motor. With dial calipers aprox. 1-3/32 dia. at the small end, aprox 1-1/2 tapper per ft. With taps as thread gages, I get an extra fine thread like 22-24 threads per inch ? I'm looking to clarify dimentions to have a hub machined & maybe a castle nut. 5/16 key. Thank you to thoese who respond
   / Roller Stator Shaft Dimentions #2
Check out page 10, illustration #22 here for the White Roller Stator standard 1 1/4" tapered shaft dimensions:
http://www.whitedriveproducts.com/pdf/catalog/2008/CEcatalog.pdf
Those motors, (and motors from other manufacturers as well), are very popular in drive wheel applications on things like scissor lifts, concrete buggies, commercial mowers, etc. 4, 5, and 6 bolt hubs are readily available as a bolt-on for the tapered shaft motors.
Here's a 4 bolt hub on eBay:
4 BOLT WHEEL HUB 1-1/4" TAPERED BORE 1-3161 | eBay
Thanks Brokenot, It goes on a floor polisher. Was I right on the taper? 1-1/2 per ft. We still need to identify the thread or will White know what it is?
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
