Roller Stator Shaft Dimentions
   / Roller Stator Shaft Dimentions #1
blake in spokane
Trying to identify tapered shaft dimentions - Rollor Stator hyd. motor. With dial calipers aprox. 1-3/32 dia. at the small end, aprox 1-1/2 tapper per ft. With taps as thread gages, I get an extra fine thread like 22-24 threads per inch ? I'm looking to clarify dimentions to have a hub machined & maybe a castle nut. 5/16 key. Thank you to thoese who respond
   / Roller Stator Shaft Dimentions #2
Check out page 10, illustration #22 here for the White Roller Stator standard 1 1/4" tapered shaft dimensions:
http://www.whitedriveproducts.com/pdf/catalog/2008/CEcatalog.pdf
Those motors, (and motors from other manufacturers as well), are very popular in drive wheel applications on things like scissor lifts, concrete buggies, commercial mowers, etc. 4, 5, and 6 bolt hubs are readily available as a bolt-on for the tapered shaft motors.
Here's a 4 bolt hub on eBay:
4 BOLT WHEEL HUB 1-1/4" TAPERED BORE 1-3161 | eBay
Thanks Brokenot, It goes on a floor polisher. Was I right on the taper? 1-1/2 per ft. We still need to identify the thread or will White know what it is?
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2007 INTERNATIONAL 4200 SBA 4X2 BUCKET TRUCK (A51406)
2007 INTERNATIONAL...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
