roller pump maintanance?
   / roller pump maintanance? #11
Personally, my hoses were just garden hose type hoses, expect the long high pressure hose from the regulator to the nozzle, so yep, I just disconnected the hoses, flushed the pump, put in the antifreeze, and capped it.
As to why you couldn't get yours back together, it had to have been one of two things; either you didn't get it clean enough or you were trying to assemble it wrong. I've had such things happen with other tools, but not with the Hypro pumps.
   / roller pump maintanance? #12
buckthorn said:
I had a pump (Hypro) seize as well, but after cleaning it and replacing the rollers, we couldn't get the thing back together again. The two large pieces didn't quite fit anymore -- it wouldn't shut. Weird.
This one is a new one on me???:confused:
Are you sure they were the correct rollers?:confused:
Are you sure the impeller was completely seated?:confused:
PALLET OF MISC LINCOLN ARC WELDER, AIR COMPRESSOR (A51244)
PALLET OF MISC...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F550...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52128)
2019 Tico Yard...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
Mini Forks (A50322)
Mini Forks (A50322)
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
