Rolled my tractor.
/ Rolled my tractor. #1
L98camino
Central Wa.
None
Hey guys. My mistake, broken leg, surgery, healing well. The tractor sat on its side on the down hill side for a week before I could get it hauled up.
My main concern now is what precautions I need to take before trying to start it (hydro lock etc).
2006 New Holland 21DA.
Thanks in advance for any suggestions, Dan
/ Rolled my tractor. #2
Oh wow, good to see you weren't injured further! Get well, and I hope it was a learning experience.
Thank you I will and yes it was.
Anyone know how to find the SN for a New Holland TC21D? Trying to register with MyNewHolland.
/ Rolled my tractor. #5
Wow, glad to hear you’re okay. Any lessons or pictures you can share?
Your sales document should have it, probably the easiest location if you’re laid up.
No seat belt, bailed off to the uphill side. Very steep slope, the roll bar and Bucket stopped it from rolling farther. It was a close call. If I had stayed on it I think my weight would have kept it rolling. Stay away from the slope is my best advice.
/ Rolled my tractor. #7
Here is a good video about bringing a machine back to life after a roll.
/ Rolled my tractor. #10
Hard to believe a broken leg is OK but at least you survived. That's a good thing. We pray for your quick recovery. :eek:
Probably all you lost was a little diesel. Any oil that leaked into the valve cover and combustion chambers will leak back to the oil pan if it's been sitting up right for a while. (Oil that may have leaked past the piston rings will most likely leak back.)
/ Rolled my tractor. #14
Best wishes for a rapid and complete recovery. Good luck in getting the tractor back in working order.
/ Rolled my tractor. #15
When you get ready to start it, just bump the starter a few times. If there is a hydraulic lock the engine will stop. Bumping means to just turn the key to start just enough to engage the starter then turn off. I would do it 5 or 6 times before trying to start. Radial engines on airplanes have a tendency to leak oil into the bottom cylinder. We pulled the propeller around a few time to check for a hydraulic lock and to get the oil out.
Thanks for the input😀 X2 on the radials lol. Good times
/ Rolled my tractor. #17
Hope you get healed up quickly and back in the saddle asap. Have you got it fired up again, already?? Good luck!!
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
211453 (A62131)
211453 (A62131)
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
