Roll over for B7800
/ Roll over for B7800 #1
GAKubotaFan
Stockbridge, GA
Kubota B7800
I am thinking about getting a Kubota B7800 and am looking at a roll over. I was wanting to know what size to get. I am leaning toward a 5'. A 5' weights about 630 lbs, so weight is not an issue. Can the 7800 pull it without bogging down? If not what about a 54" or 48"? I don't want to limit the use of the implement because the tractor may not pull it. Thanks for any input.
/ Roll over for B7800 #2
GaKubotaFan,
Okay, I'll bite and show my ignorance. What is a "roll over"?
In my mind, roll-overs and tractors don't mix very well, but obviously I'm thinking about a different "roll over".
Kelvin
/ Roll over for B7800 #3
I believe he is talking about a roll-over box blade. I have only used one once and for my needs I just could not see the advantages. Most of the ones I have seen are near double the price of a normal box blade.
GaKubotaFan, I think the answer to your question would depend on what you plan to use the blade for. I use a 5' box blade on a B21 because it is slightly wider than the rear tires on the tractor. Most of my use has been for gravel road maintenance and it has worked fine. Now with a full load of our Georgia red clay it can bog the tractor down and I have to make more, smaller cuts. Me, I would never consider a blade that did not cover the rear tracks of the tractor and would go with the smallest one that will.
What part of Georgia do you hail from?
MarkV
A roll-over is a box blade that also has rippers. It is kind of like a regular box blade except the rippers are seperate. The box rolls over to be a normal box blade or just rippers. Rippers are also know as sarifiers.
If you go to www.bushhog.com and look at their turf and landscape equipment. There is a picture of one. It may be hard to understand from the picture.
They are usually used to break new ground. I think they are good to use in rocky area's and them run a tiller throught. That way the tiller doesn't take such a beating. That is assuming you get the rocks up before tilling.
I will be using it to move grave (the box part) and break new ground. My main concern is that will the tractor pull the 5 rippers through the Georgia clay or is a smaller one better.
I live in Stockbridge.
/ Roll over for B7800 #5
I can only share my experience with a smaller tractor and a regular box blade on our clay. It depends when you try. When the moisture content is high I can tear things up pretty good, when dry I don't think you will have much luck. The compact tractors are a little light in weight to do much with dry red clay and ground engaging implements.
Something else you may want to consider is a sub soiler. On rough clay I often us the sub soiler and then switch to the sarifiers on the box blade.
MarkV
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
Case SV280B (A62177)
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
International S1900 (A63689)
International...
Yale Forklift - NO RESERVE! (A63688)
Yale Forklift - NO...
