Roll Cage Tie In Suggestions
   / Roll Cage Tie In Suggestions
I found something interesting and frankly, IMO, it makes
my suggested surface connection look twice as strong as
what I see HERE
There are 26 different full size racing cages and I believe every one of
them attaches to the vehicle w/ a 4' x 4" .25" thick plate!
That is exactly what I am doing only I add an interior plug for
more shear strength.
Here is just one of the 26, and everyone and their brother
is doing it this way.
   / Roll Cage Tie In Suggestions #43
Holy guacamolie! Waaay over thought! Jeez.
   / Roll Cage Tie In Suggestions #44
For what is worth, I have built several roll cages over the years mainly for race trucks. I have always used .095 tubing and have butt welded my A & B post to tubing off the chassis.
I have had mine and seen many others of the same basic design put to the ultimate test and I have never seen a post butt weld fail. On a roll cage all your X bracing and support links tie the cage together an spread the impact across the entire cage.
I think you will be fine butt welding you post.
Thank you for the input...
   / Roll Cage Tie In Suggestions #48
First post! Where you been!
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
200 Gallon Tank (A57148)
200 Gallon Tank...
New/Unused IRMC Massage Chair (A57454)
New/Unused IRMC...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
Heavy Duty Skid Steer Post Driver (New/Unused)(Est. Retail Value $4,900). (A59225)
Heavy Duty Skid...
