Roll Cage Tie In Suggestions
/ Roll Cage Tie In Suggestions
I found something interesting and frankly, IMO, it makes
my suggested surface connection look twice as strong as
what I see HERE
There are 26 different full size racing cages and I believe every one of
them attaches to the vehicle w/ a 4' x 4" .25" thick plate!
That is exactly what I am doing only I add an interior plug for
more shear strength.
Here is just one of the 26, and everyone and their brother
is doing it this way.
/ Roll Cage Tie In Suggestions #43
Holy guacamolie! Waaay over thought! Jeez.
/ Roll Cage Tie In Suggestions #44
For what is worth, I have built several roll cages over the years mainly for race trucks. I have always used .095 tubing and have butt welded my A & B post to tubing off the chassis.
I have had mine and seen many others of the same basic design put to the ultimate test and I have never seen a post butt weld fail. On a roll cage all your X bracing and support links tie the cage together an spread the impact across the entire cage.
I think you will be fine butt welding you post.
Thank you for the input...
/ Roll Cage Tie In Suggestions #48
First post! Where you been!
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2022 Caterpillar 289D3 (A60462)
2022 Caterpillar...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
