Roll bar modification
/ Roll bar modification #1
neilly
PA
Kubota L285
Has anybody hinged their roll bar? Interested to see how you made it work.
/ Roll bar modification #2
Any mods to a ROPS would invalidate its certification.
Gary.
/ Roll bar modification #3
Yea but they do it at the factory. Mine came from the factory hinged.
I realize that I will not be able to sue Kubota if I mod. the roll bar, but something is better than nothing, which I have now because I can't fit the tractor into the garage with the bar on.
I have a certified welder on standby while I try to figure out a hinging mechanism. I won't hold anyone responsible.
/ Roll bar modification #5
<font color=blue>I can't fit the tractor into the garage with the bar on</font color=blue>
Is it close? My ROPS was about 2 inches too tall for my shop door, but by removing some trim from the top of the opening and lowering the dirt leading up to the door, I found I could back my tractor in okay.
What's so special about backing in? Kinda hard to explain without pictures, but the fact that the ROPS is behind the rear axle, means the ROPS will pass through the door before the wheels climb up onto the slab (in my case). I've posted this doodle before, but here it is again, just as a visual aid:
I realize this may or may not be of help to you, but it might be food for thought. /w3tcompact/icons/wink.gif
/ Roll bar modification #7
There was a post (somewhere/w3tcompact/icons/tongue.gif) by someone who sawed a couple inches out of the straight sections and welded back together with solid pcs. inside the tubes for reinforcement. It would not fold but it did a nice job of lowering the clearance required.
regards
Mutt
/ Roll bar modification #8
Harv,
The reason backing in is probably working is that the ROP is slightly slanted to the rear of the tractor. In effect, you are putting in the ROPS before the tractor.
Terry
/ Roll bar modification #9
Yes, even though it's not technically legal. I fabricated mine with a piece of 1/4" plate steel, a piece of 5/8" ID black pipe and (4) 1/2" grade 8 bolts. Before removing the rops from the tractor, I marked the heighth for my cuts and marked a coupl of spots for front and back on both halves. After removing, I cut the rops in half, then cut a piece of plate to fit over the open ends which were welded in place. I then used some more plate to attach to either side of the bottom rops (rops width x 2 = 4"x4" for mine). Rear view, should resemble a U shape with the plate being higher than the bottom post. On the top rear section, I welded on the piece of black pipe for my hinge.
/ Roll bar modification #11
No. Fits very snuggly when in the down position and the design that I drew up requires critical tolerances when drilling to eliminate chattering in the up position. If drilled off, a tightening knob could be added. I looked at Long, Deere (very nice - hard to do at home), NH and Massey's for comparisons before deciding on this approach.
2011 FOREST RIVER T/A CARGO TRAILER (A67714)
2011 FOREST RIVER...
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2017 Ford F-250 Ext. Cab Service Truck (A66736)
2017 Ford F-250...
2014 CPS STEP DECK (A67714)
2014 CPS STEP DECK...
1999 22ft Express Trailers T/A Enclosed Cargo Trailer (A66738)
1999 22ft Express...
