ROLL BACK VS this
/ ROLL BACK VS this #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
ROLL BACK VS this
Which one would you rather have to haul your tractor on and why ?
/ ROLL BACK VS this #2
This is fine except you lose the tee bar option to tow something off the back.
/ ROLL BACK VS this #3
Rollback
Much better loading angle.
Ability to tow a second vehicle (when properly equipped).
Ability to unload disabled or damaged vehicles that don't roll (whole bed tilts up).
I could go on and on about all around versatility, but if all you want to do is move your tractor a few times a year, either will do. The tilting tail will be cheaper and be easier to maintain with less moving parts/ hydraulics.
/ ROLL BACK VS this
Rollback
roll back will be cheaper and will be easier to find parts for.
Aaron Z
I'm thinking it would be easier less complicated and less expensive to add a dump feature to the flat bed than it would be to add such a feature to the roll back.
/ ROLL BACK VS this #6
Brown why are you going to purchase something.Or just stir the up a talk about neat truck you seen?
/ ROLL BACK VS this #7
For a tractor like that, utility trailer behind my Toyota. Save the extra $$ for a bigger tractor and rollback :D JMO
/ ROLL BACK VS this #8
Rollback is fine for a smaller machine. Back when I had my 2090 Case which was just under ten feet tall, I deferred to the driver to put that puppy on the rollback the couple of times that I needed to have it hauled for service.
Oh', I would have loaded it had I needed to. Been there done that on other applications but why take a chance when the expert was around.
They had "pockets" ie; wheelwells up front to minimize the overall heighth. That meant backing it up with a rather high reverse gear ratio. The rear axle would accomodate duals but I ran singles all the way out for stability on the hills. The tires overhung the side of the rollback.
It's a case of what works and feels the best for you. For the cost of a rollback, I can buy a decent truck and a trailer that will give me a lot more useage.
/ ROLL BACK VS this #9
A modern rollback tilts plenty steep enough to slide a damaged vehicle off....... no need to 'add' a dump feature.
2001 International 4000 DT 466E (A60462)
2001 International...
John Deere Wheel Loader Forks (A60462)
John Deere Wheel...
2022 John Deere 1025R (A53317)
2022 John Deere...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2019 CATERPILLAR 272D3 SKID STEER (A62129)
2019 CATERPILLAR...
Iranch IRET13 (A60463)
