Rod part?
/ Rod part? #1
paulieb704
Craftsman Lt1000
/ Rod part?
Looking to find a part number for this rod and hardware
/ Rod part? #3
Welcome but to provide you with answers we need to know what make and model of this unit and any other details that you can provide.
/ Rod part? #4
and which "rod"?
/ Rod part?
Craftsman LT1000
It's the rod that connects to belt engagement lever
/ Rod part? #6
That rod was manufactured as part of a larger linkage that doesn't look like it can be disassembled. I suspect that due to its age and that it is part of a larger one piece linkage, if you are able even able to find it, it will be expensive. That model is no longer manufactured.
On the up side, the rod itself looks in okay shape, but maybe the connection rod guide on the right side is broken off or maybe the handle??
I believe I'd take it to a local welder and (s)he should be able to just fabricate whatever it wrong with it.
/ Rod part?
Thanks. Yeah this pic was from Google. I'm bringing it to my shop today to weld up and make something work. Figured I'd try finding one, but didnt have any luck. Thanks everyone
/ Rod part? #8
Today, gobs of parts are NLA, even parts for newer machines.
It's the 'planned obsolescence' philosophy as well as the buy new philosophy. With old machines today, you'd better be ready to fabricate or machine what you need or pay a high price for someone else to do it.
/ Rod part? #9
Find a used/doner deck in a wrecking yard, or MarketPlace?
/ Rod part? #11
Looks pretty simple, could you make your own? A piece of threaded rod, heat it up to make the bend, a few nuts and loctite and you could be in business.
Doug in SW IA
2017 Ford Transit Connect Cargo Van (A59230)
2017 Ford Transit...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
Unused 2025 CFG Industrial H12R Mini Excavator (A59228)
Unused 2025 CFG...
Advanced EV Cart NR (A59231)
Advanced EV Cart...
