Rocks n' Rippers
/ Rocks n' Rippers #1
BlacknTan
Platinum Member
Adirondacks of NY
Kubota B-7800
Has anyone here used a ripper like this GR-200..
http://www.gearmore.com/products/Cat_Pg75-78.pdf
to get under and lift exposed rocks up to 24" or so dia from the ground with the 3PH?
Successful, or not worth the effort?
Every year new rocks reach the surface... If it weren't for rocks, the old Adirondacks would be in a valley...
/ Rocks n' Rippers #2
I've done similar with the boxblade, can't see why it wouldn't work. 24" depends on your tractor - if buried, my m59 struggles with those. if you loosed up the soil around it would probably work better
/ Rocks n' Rippers #4
They do work, I've used one for tearing out small stumps (before I had a backhoe or mini ex). I'm sure it would pop rocks out, assuming you have enough tractor for the rocks.
Last time I used mine, I was putting in some underground low voltage wiring. I glanced off on old buried fence post. Bent the ripper and broke the 3pt top link :mad:
Ken
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2005 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A64194)
2005 Chevrolet...
Spirit Bike (A64557)
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
