Rocks n' Rippers
/ Rocks n' Rippers #1
BlacknTan
Adirondacks of NY
Kubota B-7800
Has anyone here used a ripper like this GR-200..
http://www.gearmore.com/products/Cat_Pg75-78.pdf
to get under and lift exposed rocks up to 24" or so dia from the ground with the 3PH?
Successful, or not worth the effort?
Every year new rocks reach the surface... If it weren't for rocks, the old Adirondacks would be in a valley...
/ Rocks n' Rippers #2
I've done similar with the boxblade, can't see why it wouldn't work. 24" depends on your tractor - if buried, my m59 struggles with those. if you loosed up the soil around it would probably work better
/ Rocks n' Rippers #4
They do work, I've used one for tearing out small stumps (before I had a backhoe or mini ex). I'm sure it would pop rocks out, assuming you have enough tractor for the rocks.
Last time I used mine, I was putting in some underground low voltage wiring. I glanced off on old buried fence post. Bent the ripper and broke the 3pt top link :mad:
Ken
58in Padfoot Vibratory Roller Skid Steer Attachment (A61572)
58in Padfoot...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
Pallet Fork Extensions (A64047)
Pallet Fork...
HYDRO TEK PRESSURE WASHER (A63569)
HYDRO TEK PRESSURE...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
