Rocker arm problem Allis B
/ Rocker arm problem Allis B #1
09112
N.E. Oklahoma
yanmar 3810, 48 Allis B
I've mounted my rocker arm assembly but the number four cylinder exhaust valve has not adjusted equally to the others, showing two more threads on the adjustment screw. The engine ran well initially but is sputtering intermittantly now. I have not isolated a cause for the rough running. When under power with governor open it runs as it should. without a load, at any rpm, it's pretty rough. Any ideas?
/ Rocker arm problem Allis B #2
Measure the exh valve spring height on all the cylinders and see if they are the same or very close to the same height.
Make sure the end of the rocker arm is not wore out.
/ Rocker arm problem Allis B #3
I'm wondering if your valve seat is gone on #4?
Thanks for the suggestions guys.
With some hesitation and a very red face, I come back to admit a silly mistake. While mounting the assy I neglected to put a washer under the mounting stand. That took care of the two thread difference. I really hate to click on the reply button but here goes.
UNUSED SDLANCH SDLL580 RIDE ON SKID STEER (A64280)
UNUSED SDLANCH...
GE DEEP FILL WASHING MACHINE (A64281)
GE DEEP FILL...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2014 GMC Acadia AWD SUV (A61574)
2014 GMC Acadia...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
