09112
I've mounted my rocker arm assembly but the number four cylinder exhaust valve has not adjusted equally to the others, showing two more threads on the adjustment screw. The engine ran well initially but is sputtering intermittantly now. I have not isolated a cause for the rough running. When under power with governor open it runs as it should. without a load, at any rpm, it's pretty rough. Any ideas?
