Rake Rock / Root Rake Question
/ Rock / Root Rake Question #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
I have have one of these rakes. Some of the tines are bent. Is it ok to heat the bent ones & straighten them ? Or , are they made of some type of special steel & heating them will make them weak or break ?
Thanks
/ Rock / Root Rake Question #2
Kenmac,
If it is the typical rear rake then the tines are heat treated spring steel and yes heating them will soften them. Although, if they bent instead of breaking, then they may already be softer than they should be.:rolleyes: If you try to cold straighten then they will crack and break. You could try removing them, heating and straightening and then re tempering. Or just buy new replacements. ;)
Mike
thanks mike . It is a typical rear rake. I will check on getting replacments for the bent tines
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
UNUSED WOLVERINE FORK FRAME (A64281)
UNUSED WOLVERINE...
UNUSED X-STAR 300 GALLON FUEL TRAILOR (A64280)
UNUSED X-STAR 300...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
