Rock Bucket Questions
/ Rock Bucket Questions
Mike:
How do you like the wide, grapple arms compared to the more traditional narrow ones? Somehow they look like they could take more abuse than the narrower ones.
Does the width impair visibility, or are they spaced far enough apart so it is not an issue?
I am thinking that a rock bucket with grapples and digging teeth would be almost as good as a root grapple.
I want both attachments, but can only justify one, especially if the rock bucket with grapples and teeth is almost as good as the root grapple. I suspect I am going to spend more time separating rocks than moving brush and can accept lower efficiency in moving the brush.
Dave
Mike:
Dave
/ Rock Bucket Questions #45
</font><font color="blue" class="small">( jinman...is that grapple sold by them also? )</font>
No, it is sold by Andy Tatro and I adapted it to the rock bucket. I welded up a mounting beam and then used u-bolts to attach it to the rock bucket. S-Houle does sell a grapple, but it's not like this little simple one. Consider this about the wide grapple. I can close the grapple to hold a rock or rocks and still have room on each side to dig and pick up more rocks. If the grapple was the full width of the bucket, I could not do this because the grapple would get in the way when it is closed. I do this pretty often when I'm getting two or three medium sized rocks in the bucket.
Curlydave, the visibility through the rock bucket tines is something you will love. Visibility is also a big issue with me. /forums/images/graemlins/cool.gif
/ Rock Bucket Questions #46
/ Rock Bucket Questions #47
Dave - visibility must not be an issue - cause I haven't noticed any problem - course I use it for brush mainly, and to pick up an occasional cattle guard. (txdon bought one from my FIL - I moved it for him - used that grapple just like a hand - grabbed the cattleguard, picked it straight up - backed the trailer under it, and set it down ---too cool) Digging roots and small stumps I use the center of the bucket between the grapples so again - no problem. I can see where the tines on the root grapple are too far apart for rocks so your choice of rock bucket with grapple sounds like a good one for your purposes. Will you add a toothbar to that rock bucket then? If it'll take one that should work well. Maybe Unlimited would customize the bucket for you as you want it. They don't make 'em til they have an order for one - then turn it out in a couple of days. BTW --- my first assignment with the NWS was at Medford - the radar is on top of Ashland -- hated driving that snowcat up that mountain in winter ....Texas for me forever.
/ Rock Bucket Questions #48
Their web site says they can add teeth to the bucket.
For me that is the way to go.
/ Rock Bucket Questions #51
<font color="blue"> Their web site says they can add teeth to the bucket </font> /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif shows what I get for just lookin' at the pictures /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif sounds like a plan .... My experience with them was a good one - hope yours is to if you go that way.
/ Rock Bucket Questions #52
/ Rock Bucket Questions #53
For extracting modest sized rocks and relocating them, is a rock bucket a better option than a back hoe on something like a small TLB such as a Massey 2310 or equivalent small tractor?
/ Rock Bucket Questions #54
/ Rock Bucket Questions #55
</font><font color="blue" class="small">( For extracting modest sized rocks and relocating them, is a rock bucket a better option than a back hoe on something like a small TLB such as a Massey 2310 or equivalent small tractor? )</font>
I don't think rock buckets are an option on small tractors that can't lift that much with their FEL. A rock bucket alone will weigh around 500 lb and a grapple will add 100 to 200 lb more. If you are not careful, you'll exceed the lift capacity of your loader with just the bucket. /forums/images/graemlins/tongue.gif
/ Rock Bucket Questions #56
/ Rock Bucket Questions #57
My MDS rock bucket finally showed up today. My tractor is still in the shop, or I would have assembled it and played around with it. So all I have is still-on-the-pallet shots.
It is an MDS 5' light duty rock bucket w/ JD 300/400 series loader mounts (not yet installed).
picture #1
picture #2
picture #3
I am so far impressed with this thing being called "light duty". It seems to be very stout. I can't imagine what medium, heavy and extreme duty must be like.
/ Rock Bucket Questions #58
picture #1
picture #2
picture #3
/ Rock Bucket Questions #59
How would I go about putting a grapple on this thing?
It seems that something like this would be great, but how in the heck would I mount it?
/ Rock Bucket Questions #60
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2022 Case 5550 Trident Spreader LOW HOUR (A63688)
2022 Case 5550...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
