Rock breaker on front end loader
/ Rock breaker on front end loader #1
Joshjosh654321
Whm 49hp front loader
Hey guys I looking for ideas on mounting a small rock breaker on the front of my tractor (instead of the 3 in 1 bucket)
I want to hear solutions, ideas or personal experiences and not reasons for why it won't work or any other excuses. Im even prepared to go as far as installing an additional hydraulic pump and tank if I have to
Thanks for reading and hope to hear your ideas
And no I'm not going to hire a machine to do the job so PLEASE don't recommend it
/ Rock breaker on front end loader #2
Have you researched what the flow rate and pressure requirements are for the rock breaker - jack hammer. I suspect it will require a seperate pump and reservoir to operate. Possibly use PTO driven pump and reservoir mounted on 3 point hitch.
Does that model comer with the required hydraulic “hammer” valve. If not you will have to get one of them and mount it on the loader frame or frame for the breaker.
For mounting is loader pin on type bucket or SSQA? If pin on you will need to make some type of adapter that is rigid enough to with stand the vibration and stress from the breaker.
/ Rock breaker on front end loader #3
The local rental company has one that goes on a skid steer. It works marginally well on that. An excavator is by far a better tool.
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A64553)
2014 Caterpillar...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
4 Bottom Plow (A65640)
2022 SANY SY5OU EXCAVATOR (A63276)
2022 SANY SY5OU...
