Robin Engine Charging Capacity
/ Robin Engine Charging Capacity #1
pairodime
VA
PT-425
The manual for my EH72 engine says the charging capacity is either 15 amps or 30 amps. Anyone know how to tell the difference without taking it apart? Jack, are you out there?
/ Robin Engine Charging Capacity #2
My 22 hp Robin came with a 30 amp voltage regulator which didn't last very long and was replaced under warranty. The replacement didn't last either. I worked with Jack thinking it might be the charging coils. The output of the charging coils should be 36~40V AC at 3600rpm.
The 30 amp voltage regulator is over one hundred dollars the 15 amp voltage regulator is about $20. I bought the 15 amp regulator and have been using it with out problem.
The 30 amp regulator is about twice the size of the 15 amp regulator. The part number of the 15 amp is 263-71901-01. The part number of the 30 amp is 263-719-02-A1
Hope this helps, /forums/images/graemlins/smile.gif
Dale
/ Robin Engine Charging Capacity #3
</font><font color="blue" class="small">( My 22 hp Robin came with a 30 amp voltage regulator which didn't last very long and was replaced under warranty. The replacement didn't last either. I worked with Jack thinking it might be the charging coils. The output of the charging coils should be 36~40V AC at 3600rpm.
Dale
)</font>
You're the man! You could work in my Dept! /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif
A little correction though, the AC output from the charge coil should be anywhere from 36-60V AC.
Jack
/ Robin Engine Charging Capacity #4
</font><font color="blue" class="small">( The manual for my EH72 engine says the charging capacity is either 15 amps or 30 amps. Anyone know how to tell the difference without taking it apart? Jack, are you out there? )</font>
Most likely, this engine has a standard 15amp charging system. What is the engine spec?
Jack Gawecki
Jack,
The plate on the engine has the following number- e13*97/68SN4G2*2002/88*0019*00
There is also an engine family listed of 4FJXS.7202GA
and finally a product number of EH720DS00116306
Hope this helps.
/ Robin Engine Charging Capacity #6
This engine is equiped with 15amp charging system.
Regards,
Jack Gawecki
Robin America, Inc.
Technical Support Dept.
2017 Ford F-350 Flatbed Dump Truck (A61573)
2017 Ford F-350...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
2006 Dodge Grand Carvan Van (A61574)
2006 Dodge Grand...
KMC 3386 (A64119)
KMC 3386 (A64119)
Schulte Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Schulte Batwing...
John Deere Z994R (A60462)
John Deere Z994R...
