rmankty
/ rmankty #1
rmankty
Bronze Member
1948 farmall cub
HELLO,I OWN 1948 FARMALL CUB HAVE USED CUBS FOR YEARS TO PLOW SNOW,PUT IN GARDENS, HANDLE WOOD AND CUT GRASS WITH BELLY MOWER. GREAT MACHINES WHICH LASTS FOR GENERATIONS. I HAVE NOW STOCK TIRE AND WHEELS ON FRONT END. WANT TO SET UP WITH TUBELESS TIRES AND MATCHING WHEELS FOR EASE OF USE AND MAINTENANCE.TRYING TO FIND A SET NEW FOR BEST PRICE,ANY IDEAS? THANK YOU FOR SUGGESTIONS!
/ rmankty #3
I hope this may help. You should be able to purchase the tires or comparable size tires at a local tractor dealer. In NC our farm bureau has a CO-OP that sells tires at a reduced rate, but I don't know about your area. Obtaining the rims will be somewhat more difficult. Perhaps you can check out the upcoming farm equipment auctions in your area. Or you could hang out at your local feed store or hardware store and ask around. Another option would be to look on Craigslist. Hope this helps somewhat. Good Luck. :tractor::welcome:
/ rmankty
Thanks for advice! Ive found wheels/tires,and I am looking to either put 2nd set of wheel weights on back, or add some weight between rear wheels. Any suggestions? Thank you in advance.
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
UNUSED WOLVERINE QMP3-16-6T QUICK ATTACH PLATE (A62131)
UNUSED WOLVERINE...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
