RK50HC - Automatic DPF Regeneration Experience
   / RK50HC - Automatic DPF Regeneration Experience
Re: RK55HC - Automatic DPF Regeneration Experience
I have almost 300 hours ...Mine has regened about 6 times. ...No issues with the regen or the tractor.
Have you done a stationary regen yet?
   / RK50HC - Automatic DPF Regeneration Experience #12
No, I have not. I have been able to keep working when it called for the automatic regen and everything seems to work fine. We have had to do the stationary one every so often on the forklifts at work. They are Hyster forklifts with Kubota diesels in them. It is the nature of the way the forklift operates. A lot of low rpm work loading lumber. The engine just does not get run hard enough, long enough to generate the heat. On those we just set the parking brake and hit the button. The engine picks up rpms and does it's thing. On my RK I can run the rpms up while I am working it and it has done fine with the auto regen.
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52709)
2013 CATERPILLAR...
JOHN DEERE 624K WHEEL LOADER (A58216)
JOHN DEERE 624K...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
LOT OF FLAT IRON (A58374)
LOT OF FLAT IRON...
2007 Sterling Acterra Service Truck, VIN # 2FZACFDC67AY51272 (A57453)
2007 Sterling...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
