RK24 fuel system priming?
/ RK24 fuel system priming? #1
Ohio RK24
Bronze Member
2019 RK24
Curious if anyone here has had to prime their RK24 due to running out of fuel, I am wondering what steps would be required to accomplish priming.
I guess that I am either not understanding and or missing it in the manual, I have had people tell me that newer tractors should be self priming. Just curious , if anyone knows the facts on this procedure.
/ RK24 fuel system priming? #2
If your machine has an electric supply pump, turn the key on.. THEN, loosen the inlet banjo at the injection pump inlet.. look for clear fuel with no bubbles.
Once u get good fuel at the inlet, tighten the bolt..
NEXT, loosen ALL the steel lines from the pump TO THE INJECTORS.. AT THE INJECTORS & crank the engine until fuel squirts out of the loosened lines WITH NO AIR.. & tighten..
It should start now..
Good luck..
Good luck..
Thanks for info.
/ RK24 fuel system priming? #4
So this happened to me, see my post. The manual sucks! But, you shouldn't have to do any priming. With my tractor, it started right up, ran 10. -15 sec's, then died. If that happens, check the fuses! RK 24 out of fuel
/ RK24 fuel system priming? #5
There is a thumb pump to prime the filter bowl on the side of the fuel pump. Just pump it until the filter bowl is full and a few more times for good measure.
I appreciate the information, thank you for taking the time to help out.
