RK21 Backhoe
   / RK21 Backhoe #1
springer0707
RK21
I purchased an RK21 yesterday and was wondering why a backhoe attachment is not offered? Will a backhoe from a Mahindra eMax20S fit? It looks to have the same specs as far as PTO speed. I was thinking of the Mahindra 23B backhoe. Do you think it would work?
   / RK21 Backhoe #2
Reason being, the frame would not hold up to the twisting and hammering. Best to have gotten the RK27 instead.
   / RK21 Backhoe #3
Hey, welcome to TBN and congrats on the new tractor.
I can't answer the question of why. But I can tell you that if tym/rk decided not to match a backhoe to that platform, they certainly would not cover any damage to your tractor caused by a backhoe.
Do you have any hydraulic remotes in the rear to power a backhoe? If not, that's the first hurdle. These backhoes run off tractor hydraulics not directly from the 540rpm pto.
I strongly recommend that you do not try to use any backhoe made for a 3pt hitch mount that does not have a subframe. Do some reading on those things if unfamiliar. You will see quickly that you can literally break your tractor in half without a subframe.
A new bh that size is $4-5k+, you could rent a backhoe or mini excavator for a while for that $.
Just food for thought.
2017 Ford F-150 Crew Cab Pickup Truck (A48081)
2017 Ford F-150...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
2024 Icon LT-A617.4+2G Electric Golf Cart (A48082)
2024 Icon...
2012 GALLEGOS TRAILER 130BBL VAC TRAILER (A50854)
2012 GALLEGOS...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
UNUSED 20 in. Gasoline Chain Saw (A50860)
UNUSED 20 in...
