RK21 Backhoe
/ RK21 Backhoe #1
springer0707
RK21
I purchased an RK21 yesterday and was wondering why a backhoe attachment is not offered? Will a backhoe from a Mahindra eMax20S fit? It looks to have the same specs as far as PTO speed. I was thinking of the Mahindra 23B backhoe. Do you think it would work?
/ RK21 Backhoe #2
Reason being, the frame would not hold up to the twisting and hammering. Best to have gotten the RK27 instead.
/ RK21 Backhoe #3
Hey, welcome to TBN and congrats on the new tractor.
I can't answer the question of why. But I can tell you that if tym/rk decided not to match a backhoe to that platform, they certainly would not cover any damage to your tractor caused by a backhoe.
Do you have any hydraulic remotes in the rear to power a backhoe? If not, that's the first hurdle. These backhoes run off tractor hydraulics not directly from the 540rpm pto.
I strongly recommend that you do not try to use any backhoe made for a 3pt hitch mount that does not have a subframe. Do some reading on those things if unfamiliar. You will see quickly that you can literally break your tractor in half without a subframe.
A new bh that size is $4-5k+, you could rent a backhoe or mini excavator for a while for that $.
Just food for thought.
APPROX. (15)-16' HDPE PIPE (A62131)
APPROX. (15)-16'...
UNUSED TAYLOR-WAY 6' BOX BLADE (A62130)
UNUSED TAYLOR-WAY...
Kubota M6060 Tractor (A61166)
Kubota M6060...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2014 BMW 28I AWD SUV (A61569)
2014 BMW 28I AWD...
New/Unused 3 Point Ball/Flat Hitch (A61166)
New/Unused 3 Point...
