RK Tractor reviews???
Status
Not open for further replies.
/ RK Tractor reviews??? #41
That's nice. Of course Yanmar and Kubota are both Japanese companies. But fine, they make great tractors, which is the most important thing. Which is my point, I think. :)
BTW, your Mahindra is a Mitsubishi through and through, except for the loader (I think that is US made by a supplier). They are another great Japanese brand.
/ RK Tractor reviews??? #42
Yep, the label on the FEL says made in USA.
My little car with the Mitsubishi 4-banger was the most reliable car I had ever owned up to that point--great little engines.
/ RK Tractor reviews??? #43
I purchased the RK37HC three weeks ago and have put right at 12 hours on it mowing pasture. I like everything about it so far except for one. The PTO lever is at the left side of the seat and numerous times when exiting the tractor I managed to knock the knob off the end of the lever. As far as having a cab with AC, in this day and time here in Florida it's almost a necessity rather than a luxury in the summer. My local Rural King has only been selling the tractors for a few months and the King Kutter implements even less so parts for the implements haven't seemed to make it to the store yet. I bought a rotary cutter along with the tractor and managed to break the shear bolt on the PTO shaft. Went to the store and they didn't have them which I found kind of odd since you can't use the mower without it but I didn't even see replacement blades. I did find them on their web site but rather than wait I went to Tractor Supply and got a pack of 5. But other than the PTO level issue I love my tractor so far.
/ RK Tractor reviews??? #44
fyi, if your king kutter uses a thru bolt style like my old one does, then you can use a grade 2 bolt of the right dimensions if you ever get stuck again. Remember.. soft grade 2, no head marks.
/ RK Tractor reviews??? #45
My King Kutter has the pass thru grade 2 bolt shear pin.
I'm surprised I haven't sheared it yet.
/ RK Tractor reviews??? #46
My King Kutter HD uses grade 2, 3"x1/2" shear bolts. They shear all the time! I've gone thru 6 bolts. It will shear even though I have the rpms at idle and the mower up or down. I replaced them with grade 5. I know this puts my gearbox at risk, but the cutter is worthless if I can't get it to spin. With the grade 5s I've had no problems yet. Hoping it keeps going that way. But at least I can get some mowing done now.
/ RK Tractor reviews??? #47
Girl w/ tractor,
I take exception to your post # 11, "There are quite a few differences between the 2638 and the RK37, according to the specs. For one thing, the RK is longer and narrower.
RK37 L: 126, W: 53.5
2638 L: 119.3 W: 63.2"
I can't dispute your reference, however it is does NOT seem that this significant a disparity exists. Hope the RK Guy will enlighten. I have no affiliation w/ RK but I respect their efforts to offer quality equipment at very reasonable prices.
Were you aware that your tractor is a rebranded Mitsubishi prior to the sale,? Did the dealer disclose the fact? Again, my only interest is that RK is treated fairly, and that accuracy and unbiased descriptions of their products is fairly represented in these forums.
As for prof fatalist, he bought an economy tractor, which unto itself is just fine. Kioti does NOT dispute this is an entry level machine designed to meet a specific price point. The SE version is more comparable to the RK models, equipped w/ the bells and whistles of a premium tractor. Some folks just can't admit they did NOT purchase the most value for the money so the immediate reaction is to attack the superior value. This is childish and immature. NY Cheese did an extensive review of basic vs SE models in his recent tractor purchase thread & subsequent posts.
I too purchased an economy level Kubota tractor. Eyes wide open, I could have received more options for less cost through another brand. I do NOT diminish the other brand, because I made this choice.
If I were in the tractor market today, I would purchase an RK machine, Likely the 74 hp Cab/Power Shuttle model w/ the Deutz power plant. I would avoid the DPF emissions given a choice, since higher operating engine revolutions is NOT really my preferred style . Unless I need the RPM's for a PTO implement, travel from point A to point B is approached rather casually.
NOTE: The whole discussion over HST vs Gear and On-Highway manual vs automatic drivetrains was at best kinda silly. Once begun, there is no graceful way to retract that which should NOT have been stated or IMPLIED in the first place. Tongue in cheek often becomes foot in mouth.
EDIT:
Girl w/ Tractor,
Sincere apologies as my defending RK comment was a general comment, more applicable to prof fatalist. My concern w/ your post was simply that two tractors in the same class should be similar in overall width and that is a product of tire type, size and wheel spacing rather that axle design and cast hub width. Smaller tractors have fewer spacing options, yet still dependent upon wheel mount position? Just my experience.
/ RK Tractor reviews??? #48
Girl w/ tractor,
RK Tractor Guy has already addressed this issue of differences between the two. Basically, even though TYM makes many components of both Mahindra and RK tractors, they are not identical tractors by any means.
Certainly I was fully aware that various components of Mahindra tractors are sourced from different countries, like most modern tractors. For example, Deere tractor components (<100 HP) come from Japan, Mexico, India, Canada, Germany, and China. Not sure why you call Mahindra a "rebranded Mitsubishi." True, many Mahindras have Mitsubishi engines (great engines) and probably other Japanese components. Mahindra owns 33.3% of the Mitsubishi company. The FEL is made in the USA. Other components come from other companies/countries, which I personally have no problem with. YMMV
I have defended RK in this thread so perhaps that comment was directed at someone else.
/ RK Tractor reviews??? #49
Hey everyone, let's have fun with this forum. Do you know the story of how Tractorbynet began? Amazing. Muhammad Chishti started Tractorybynet 20 years ago at the age of 13! His family lived on a dairy farm in update NY and he grew up with a love of tractors. So, think about the INTERNET in 1998. Muhammad wanted to create a place where people could share information about tractors. There were few places to go outside of visiting a dealer, and think about what the tractor manufacturers had for websites. Not really much there. So Muhammad, again, at 13 starts a forum where people become a community of information seekers and sharers. Now, 20 years later, a half million users later and Tractorbynet remains the definitive place to go to learn about compact tractors. I spoke to Muhammad a few months ago and he shared the story. Only in America! How many websites begun in 1998 are around today, still growing? Now, 33, Muhammad still runs Tractorbynet, and he has a "day job" too.
Wanted to share Muhammad's story to remind everyone of why this forum was established 20 years ago. To form a community of people sharing information with one another, about their common interest in tractors. Once in a while, some users get a little off track when they seem to make it personal, and sort of try to project themselves as smarter than other users. Let's not do that here on the RK Tractors forum. Let's be different as a group, just as we are trying to be different as a tractor company. Straight forward, helpful to one another and sharing what we know in the spirit of community that Muhammad intended 20 years ago. Muhammad was gracious enough to give RK Tractors its own space on Tractorbynet. We know that people are out there in other brand forums saying not so nice things about RK Tractors. That's ok, we'll just stick to this space and do what we can to answer people's questions about RK Tractors.
/ RK Tractor reviews??? #50
Are your holes sloppy? That will make them shear...
Imho, I would care less about the mower gearbox than my tractors pto...
Good luck
I'm still uncertain on making a tractor purchase from a retail store. I haven't been 100% convinced they will still be in the tractor business 5 years from now.
/ RK Tractor reviews??? #52
I'm sure that uncertainty is shared by others as well, and that it factors into RK's introductory pricing. :)
/ RK Tractor reviews??? #53
I searched the Internet for a month gathering any and all info about SCUTS , creating spread sheets, comparing specs, and of course, a major player, price. I did come across the RK tractors and found them to be one of the top contenders. Unfortunately, there are no stores anywhere close. Shipping costs put them out of contention. If they opened a store within about 500 miles from me, I would buy one of their tractors.
I ended up driving 550 miles each way to pick up my LS scut. Basically the same identical tractor as the NH workmaster 25S. (It is the same tractor, "re-branded" as a NH, made by LS). Why would I pay $4-5K more just to have NH decals on it? I don't rely on the dealer to do any service. They have been excellent shipping a couple of 'factory service bulletin' parts to me, which I installed myself. Now that the local NH dealer is finally selling/servicing the workmaster line, I can get parts locally if needed. I have put 135 hours on my little SCUT so far and it has been fantastic!
What RK Tractor Guy states makes sense. If you cut out the middle man, that savings can be used to pass on to the consumer. Every tractor manufacturer can have a "lemon" or a certain line that has defects. So can Chevy, Ford, Toyota, etc... I would not base a decision upon who is selling, but rather base the decision on quality, price, and of course, bang for the buck.
My initial purchase was based on what I could afford at the time, and naturally 'the best bang for my meager bucks'. What I was able to get has helped me considerably. Was it what I wanted to get? No. Will it be my only tractor purchase? No. I will get another tractor, based upon my future needs, but not right now.
I think that RK is filling a needed void in the marketplace. They are creating competition between brands, which means better quality, price, and customer support is required to capture a market share. Brands like Kubota and Deere have already established themselves. It's now the other guys that have to prove themselves. There are only 3 "local" dealers near me, K, D, and NH. They all have the "I don't care" attitude, raise their prices competitively higher than other regions / states. They may have a proven track record, but I personally would never ever buy one of those tractors. I may be strange, have a different way of thinking, but maybe I just root for the underdog.
I hope RK does what they say, stands behind their equipment, and upholds their integrity. In today's day and age, that would make them a winner in my book.
/ RK Tractor reviews??? #54
Our pricing is not low because it is introductory, our pricing is low because we buy our tractors directly from the tractor manufacturer, built in our brand and to our specifications, and then sell directly to the tractor user. Every other brand sells to a dealer first. That means our cost is much lower than that of the dealers we compete with. Our pricing will be adjusted once per year on Jan 1 based solely upon any changes to what our manufacturer charges us, but every brand sees annual price changes. We will always be far below anyone else.
As for whether we will be around in five years selling tractors, our company is a family and employee owned, American business began in 1960. We launched RK Tractors at seven locations in April 2017, ranked 14th of 14 under 60 HP tractor brands in the U.S. in unit tractor sales because we started at zero sales. We are at 40 locations today, and we will be at 60 locations by March 2019, and at all 115 Rural King locations in 2020. We won’t reveal where we rank now in Sales other than say we have already passed many brands that have been around for 10 years or more.
We’ll be around in five years, and 25 for that matter. We do understand why we need to keep sending that message though. All we can do is share our plans and stick to our commitments.
Good morning RK tractor guy! Great to see you involved in this thread. My quote involving 5 years from now didn't necessary refer to RK in general but the tractor sales and service. My RK is actually only 5 minutes from my house so the convenience is awesome. The tractor guy at my local RK store (Joe) is awesome and yes he has sold me on the tractor but I would love to see the service side of RK. When spending potentially 30k a person has to be 100% sure of everything. I love the RK37 size and features. I may see if Joe can allow me to walk thru the service area and talk to who may be over that as well. Our Morganton RK seems to be always busy!!
/ RK Tractor reviews??? #56
Good luck
It seems like a pretty snug fit. I'm using 1/2" bolts. I'm wondering if maybe I should be using metric bolts. They might be a mm thicker? I'll have to do a little research.
/ RK Tractor reviews??? #57
Our pricing is not low because it is introductory, our pricing is low because we buy our tractors directly from the tractor manufacturer, built in our brand and to our specifications, and then sell directly to the tractor user. Every other brand sells to a dealer first. That means our cost is much lower than that of the dealers we compete with. Our pricing will be adjusted once per year on Jan 1 based solely upon any changes to what our manufacturer charges us, but every brand sees annual price changes. We will always be far below anyone else. [snip]
RK Tractors has developed its own business model, and I sure don't mean to be argumentative, but be careful what you promise. :eek: Saying that your future pricing will be adjusted solely upon any changes to what your manufacturer charges you leaves decisions on price increases exclusively to your manufacturer. Doesn't that essentially put handcuffs on RK's bean counters? :laughing: It limits the potential for increasing profitability strictly to growth in volume of future sales.
Every other tractor brand is free to increase prices based in large part on demand, not just cost. And many have done that, as their reputation, cachet and brand loyalty have grown over the years. In a free-market economy, why would RK give that opportunity up? :confused: No one is expecting the family to run its tractor business as a public-service enterprise!
/ RK Tractor reviews??? #58
Threepoint,
As stated, it appears RK is in this for the long game. The conditions and variables you suggest are years down the road. Believe the objective is to first prove to the tractor buying community that they are committed to this tractor endeavor.
Secondly, it is important to secure a sound position in overall market share. Getting to the # 1 position and remaining there are two different scenarios.
Thirdly, RK can see how price inflexibility and arrogance is currently undermining those that share the current top positions. It is an advantage to start at the bottom and observe what is and is NOT working for the market leaders.
Lastly, the RK philosophy, as they also sell many different products, is too demonstrate a VERY COMPETITIVE posture in the marketplace. This is their historical profile since the beginning. Since the leopard does Not change its' spots, it is reasonable to expect RK to employee the same marketing approach to tractors, LONG TERM.
They aren't just another one trick pony, they have a traceable track record, and I believe they have their sights set upon the LONG GAME, Sell for a reasonable competitive price, and sell more...…………..
/ RK Tractor reviews??? #59
I was thinking the same thing when you consider all the people who got screwed on warranty buying from Cabella's BUT I do believe there's a big difference between Cabella's and RK. Cabella's is more of a sporting goods store that happened to try selling tractors whereas RK is an actual farm type store. IMO that is a HUGE difference going into it because tractors seem like a good fit for the RK product line but it would still make the decision more complicated for me as well. Cabella's really had no business getting into the tractor business.
/ RK Tractor reviews??? #60
Tractor NH,
I think the Cabella issue is exaggerated. We need to be careful when equating warranty support and long term dealer support. If the #'s were as inflated as suggested, there would have been multiple class action legal actions.
Lexis Nexis did not reveal any class actions?
Do YOU personally know anyone affected by a failure to execute warranty support? No one wants to see their dealer cease operations. A question was posed to RK if they would provide parts for Cabella owners? The answer is affirmative.
No ONE likes what occurred w/ the Cabella situation, but at this point it doesn't serve anyone's interest to paint RK w/ that same brush. RK had NO connection to that relationship. Let's analogize and draw a correlation on a much more personal level.
Presume for a moment, a member of YOUR family committed a crime against society. Shall we ALL then assume that since this is YOUR relative, YOU are likely to also commit a similar crime? Is that fair?. Well it is not fair to RK either!!!
Status
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2001 WESTERN STAR  4900E (A65643)
2001 WESTERN STAR...
17395SFL (A61568)
17395SFL (A61568)
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
3 Point Bale Mover (A65640)
3 Point Bale Mover...
KUBOTA SVL95-2S (INOPERABLE) (A65643)
KUBOTA SVL95-2S...
