RK 24 3rd Hydraulic Line purpose
   / RK 24 3rd Hydraulic Line purpose #1
Iceman Batten
RK24
There are 3 hydraulic lines for the RK24 backhoe. It works properly with only two of them connected. What is the purpose of the 3rd line? The two I have connected are the larger connectors which (on the tractor side) have to be connected together when the backhoe is removed. The 3rd line is slightly smaller, and I would like to know what it is for, since the backhoe works normally with out that line connected.
   / RK 24 3rd Hydraulic Line purpose #2
Most often an odd line is for a case drain. Usually smaller than the others. That would be unusual for a backhoe since a case drain is relieves excess pressure in a rotating implement like a wheel motor or auger head.
I attached a page from your bh manual w the hydraulic diagram. It shows a 3rd hose but I'm not sure for what.
My rk55 backhoe only has two.
Can you post a picture?
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2020 FREIGHTLINER LT625 CASCADIA SLEEPER (A57880)
2020 FREIGHTLINER...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
2014 Ford F-550 (A55973)
2014 Ford F-550...
