RK 24 3rd Hydraulic Line purpose
   / RK 24 3rd Hydraulic Line purpose #1
Iceman Batten
RK24
There are 3 hydraulic lines for the RK24 backhoe. It works properly with only two of them connected. What is the purpose of the 3rd line? The two I have connected are the larger connectors which (on the tractor side) have to be connected together when the backhoe is removed. The 3rd line is slightly smaller, and I would like to know what it is for, since the backhoe works normally with out that line connected.
   / RK 24 3rd Hydraulic Line purpose #2
Most often an odd line is for a case drain. Usually smaller than the others. That would be unusual for a backhoe since a case drain is relieves excess pressure in a rotating implement like a wheel motor or auger head.
I attached a page from your bh manual w the hydraulic diagram. It shows a 3rd hose but I'm not sure for what.
My rk55 backhoe only has two.
Can you post a picture?
202479 (A54757)
202479 (A54757)
Deere 331G (A53317)
Deere 331G (A53317)
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
20704 (A55853)
20704 (A55853)
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
