Rivet tools
/ Rivet tools #4
To those who use these rivet tools. How does this work?
My sicklebar mower sections use 5mm beveled rivets. Both the bar and the section blades have beveled holes. Currently I remove the bar from the mower. Use a hand grinder to grind out the beveled rivet head on the old section. Knock off the old section with a hammer. Chisel the remaining stub off smooth with the bar. Then punch out the rivet from the bar.
Does this tool just press the entire rivet out of the bar/section without all that work above? Will it work on metric rivets?
/ Rivet tools
Here are the instructions. I haven't used it to remove one with the rivets still in the bar yet.
Solo
/ Rivet tools #6
Thank you.
I know I would have to remove the blade as mine is a double action mower. Cutting blade moves one direction while the rock guard moves in the opposite direction.
One thing I am concerned about is mine is metric rivets. 5mm, that is about .20 inch. As it is smaller than the normal .25 inch rivets, I wounder if it would be any problems.
/ Rivet tools
waytech
It does remove the entire rivet. I just punched one out of a bar to try it. My rivets are 3/16" (.187)
Solo
/ Rivet tools #8
I think I will get one and try it
Thank you much
2013 INTERNATIONAL PROSTAR+ 113 (A67714)
2013 INTERNATIONAL...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65054)
2001...
2012 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2012 FORD F150...
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
2016 Ford Escape SUV (A66738)
2016 Ford Escape...
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
