Rivet tools
/ Rivet tools #4
To those who use these rivet tools. How does this work?
My sicklebar mower sections use 5mm beveled rivets. Both the bar and the section blades have beveled holes. Currently I remove the bar from the mower. Use a hand grinder to grind out the beveled rivet head on the old section. Knock off the old section with a hammer. Chisel the remaining stub off smooth with the bar. Then punch out the rivet from the bar.
Does this tool just press the entire rivet out of the bar/section without all that work above? Will it work on metric rivets?
/ Rivet tools
Here are the instructions. I haven't used it to remove one with the rivets still in the bar yet.
Solo
/ Rivet tools #6
Thank you.
I know I would have to remove the blade as mine is a double action mower. Cutting blade moves one direction while the rock guard moves in the opposite direction.
One thing I am concerned about is mine is metric rivets. 5mm, that is about .20 inch. As it is smaller than the normal .25 inch rivets, I wounder if it would be any problems.
/ Rivet tools
waytech
It does remove the entire rivet. I just punched one out of a bar to try it. My rivets are 3/16" (.187)
Solo
/ Rivet tools #8
I think I will get one and try it
Thank you much
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2021 Berti 112in. Handy 230-280 Hydraulic Flair Mower Tractor Attachment (A66734)
2021 Berti 112in...
2016 FORD F450 CREW CAB SERVICE TRUCK (A69167)
2016 FORD F450...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
SDlanch SDLGC8 Electric Golf Cart (A64912)
SDlanch SDLGC8...
2018 GMC Sierra 1500 Crew Cab Pickup Truck (A66736)
2018 GMC Sierra...
