Ripped sidewall on r1 tire
   / Ripped sidewall on r1 tire #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
I just sliced the sidewall on my titan hi traction r1 8-16 front tire. Can I put a tube in it? Tractor has 195 hrs so very little wear on the tires. A new one seems to be about $175. What is my best option? What about a different brand? I see that Carlisle and Jetzon seem cheaper than the Titan brand.
Can I mix a diff brand of r1 tire without causing a problem? I also came across a sidewall patch from Patch Rubber Company. Has any one heard of this?
   / Ripped sidewall on r1 tire #4
I would get a tire professional to check on putting a "boot" in the tire then a tube. This "fix" will depend on how long and deep the cut is, that is why you need a tire expert to look at the tire. A different brand tire will need to have the same circumference as the one that is on your tractor now.
   / Ripped sidewall on r1 tire #5
As amaxwell said - if the slice isn't too big, you can get a boot. It's a hard piece of rubber that goes against the inside of the tire slice. Then you put a tube in the tire. I've used them with good results.
   / Ripped sidewall on r1 tire #6
Just bite the bullet and get a new tire , a cheap fix probably wont last , and will fail just before a major snowstorm on a holiday weekend and the tire will be on back order ..................when you need it most .
   / Ripped sidewall on r1 tire #7
Another option might be to patch it and then have it filled with foam. I don't know how much flex the tire would have though.
   / Ripped sidewall on r1 tire #8
I foamed filled my damaged sidewall... so far so good.
   / Ripped sidewall on r1 tire #10
I have used boot laces to sew up split sidewalls. After sewing, glue a boot inside, (not your work boot, LOL), install a tube and go back to work. some of those fixes seem to last forever, and some not so good.
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2019 International DuraStar 4300 2,000 Gallon Water Truck (A50323)
2019 International...
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A51572)
2015 International...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A50323)
2007 Western Star...
2007 PETERBILT 379 (A52472)
2007 PETERBILT 379...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
