Ripped sidewall on r1 tire
   / Ripped sidewall on r1 tire #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
I just sliced the sidewall on my titan hi traction r1 8-16 front tire. Can I put a tube in it? Tractor has 195 hrs so very little wear on the tires. A new one seems to be about $175. What is my best option? What about a different brand? I see that Carlisle and Jetzon seem cheaper than the Titan brand.
Can I mix a diff brand of r1 tire without causing a problem? I also came across a sidewall patch from Patch Rubber Company. Has any one heard of this?
   / Ripped sidewall on r1 tire #4
I would get a tire professional to check on putting a "boot" in the tire then a tube. This "fix" will depend on how long and deep the cut is, that is why you need a tire expert to look at the tire. A different brand tire will need to have the same circumference as the one that is on your tractor now.
   / Ripped sidewall on r1 tire #5
As amaxwell said - if the slice isn't too big, you can get a boot. It's a hard piece of rubber that goes against the inside of the tire slice. Then you put a tube in the tire. I've used them with good results.
   / Ripped sidewall on r1 tire #6
Just bite the bullet and get a new tire , a cheap fix probably wont last , and will fail just before a major snowstorm on a holiday weekend and the tire will be on back order ..................when you need it most .
   / Ripped sidewall on r1 tire #7
Another option might be to patch it and then have it filled with foam. I don't know how much flex the tire would have though.
   / Ripped sidewall on r1 tire #8
I foamed filled my damaged sidewall... so far so good.
   / Ripped sidewall on r1 tire #10
I have used boot laces to sew up split sidewalls. After sewing, glue a boot inside, (not your work boot, LOL), install a tube and go back to work. some of those fixes seem to last forever, and some not so good.
2014 Ford F-550 XL (A50120)
2014 Ford F-550 XL...
Bush Hog PT 10' Mower (A50120)
Bush Hog PT 10'...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
