RIMS STUCK TO AXLE
   / RIMS STUCK TO AXLE #1
grprou
perry hall maryland
dynamark
How do you remove rims with tires stuck frozen to axle 36" riding mower?
   / RIMS STUCK TO AXLE #3
Remove nuts, spray rust penetraiting spray on hub and studs ,install nuts, leave nuts one or two turns loose, drive around turning side to side to put a side load on wheels.
If this does not work, respray and let set overnight and try driving again. Also heat may help. Good luck!
   / RIMS STUCK TO AXLE #5
10 pound hammer does it.
   / RIMS STUCK TO AXLE #6
With the key @ 12:00, drill a hole in the wheel and then using a sawsall split the hub down to the key. Drive a wedge into the saw kerf both inboard and outboard. Pull the wheel and on re-assembly apply your favorite grease, never seize compound or oil if that's all you have handy. This one has been running re-assembled like this since 2005.
This is only one example of many ways to accomplish the task and the reason I chose this method is these tools are what I had at the moment to do it with.
If you would rather repair the transaxle, buy a new transaxle or new lawn tractor, force it.:thumbsup:
   / RIMS STUCK TO AXLE #8
Make a puller.
A bar with 2 holes to match holes in rim and a tap hole in middle to jack with . Should work with a little wd40 or heat.
   / RIMS STUCK TO AXLE #9
Depends on what type of wheel/axle.
If it has lug-nuts, this is a good method.
If it is just one center nut, this is good
Make a puller.
2020 Isuzu NPR Heil 8RLDB 8CuYd Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
2015 Kubota KX91-3S2 Mini Excavator (A52377)
2015 Kubota...
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2016 KENWORTH T370 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T370...
2013 CAT 246C (A47477)
