RIMS STUCK TO AXLE
   / RIMS STUCK TO AXLE #1
grprou
perry hall maryland
dynamark
How do you remove rims with tires stuck frozen to axle 36" riding mower?
   / RIMS STUCK TO AXLE #3
Remove nuts, spray rust penetraiting spray on hub and studs ,install nuts, leave nuts one or two turns loose, drive around turning side to side to put a side load on wheels.
If this does not work, respray and let set overnight and try driving again. Also heat may help. Good luck!
   / RIMS STUCK TO AXLE #5
10 pound hammer does it.
   / RIMS STUCK TO AXLE #6
With the key @ 12:00, drill a hole in the wheel and then using a sawsall split the hub down to the key. Drive a wedge into the saw kerf both inboard and outboard. Pull the wheel and on re-assembly apply your favorite grease, never seize compound or oil if that's all you have handy. This one has been running re-assembled like this since 2005.
This is only one example of many ways to accomplish the task and the reason I chose this method is these tools are what I had at the moment to do it with.
If you would rather repair the transaxle, buy a new transaxle or new lawn tractor, force it.:thumbsup:
   / RIMS STUCK TO AXLE #8
Make a puller.
A bar with 2 holes to match holes in rim and a tap hole in middle to jack with . Should work with a little wd40 or heat.
   / RIMS STUCK TO AXLE #9
Depends on what type of wheel/axle.
If it has lug-nuts, this is a good method.
If it is just one center nut, this is good
Make a puller.
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
1272 (A50490)
1272 (A50490)
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
