Rimfire verses center fire
   / Rimfire verses center fire #31
HomeBrew2
I forgot the .219 Zipper, owned a couple of them a few decades back and then there was the 22 Savage HiPower but it was actually .228 caliber.
BillyP
My home gun is a Ruger Blackhawk in .38-40 which is actually .401. I have a 10mm Auto cylinder for that gun also.
Vernon
   / Rimfire verses center fire #32
DieselPower said:
I would have to disagree with part of that. Being hit by a 22 rimfire, especially a 22LR is not like being hit with a slingshot. A 22 rimfire can kill a groundhog dead just like a 22-250 can. You just have to have a better placed shot with the rimfire. :)
Let me dust off one of my bullet comparison pic's. I will list the relevant calibers. Starting at the left. 22 BB cap, 22 CB cap, 22 Short, 22 Long, 22 Long Rifle, .17HMR ballistic tip, .17HMR hollow point (both of these are also rimfire cartridges, (not relevant but it's next) 30 Carbine, 223 Rem (a 22 caliber bullet and used in AR15's, M16's) and at the end is a 50BMG.
As you can see there is quite some difference in the capacity of a cartridge as to how much powder it can hold. Larger powder capacity, more power, higher velocity and kinetic energy. Also with the larger capacity cartridge cases you will usually find that the bullet weight increases.
Yes this is true but...
Which one would you rather be shooting for 300yd shots? .22 rimfire or 22-250.
   / Rimfire verses center fire #33
schmism said:
if you can TRANSFER the engergy to the flesh! a through and through shot on a fully jacketed round and your not going to have much "knock down power"
a .17 HMR with blastic (plastic) tip, designed to fragmet on impact transfering almost its entire energy to the target = drop em dead on impact
you want to reliably drop ground squirls /prairy dogs etc at 150 yds you need the .17 HMR
if your into longer range "reach out and touch someone" for varmit hunting 200 yard + you need to step up to a 22-250.
I knew someone would go into this detail:/..... I was just trying to give an example without all the little details for someone that is not fimilar with all the details.
   / Rimfire verses center fire #34
The 22-250 of course. :)
On the different 22 center fire's that come to mind in modern times.
22 Hornet .224
22 K Hornet .224
218 Bee .222 or .224
221 Remington Fireball .224
222 Remington .224
223 Remington (5.56x45mm) .224
222 Remington Magnum .224
22 PPC .224
5.6 x 50 Magnum .224
219 Donaldson Wasp .224
219 Zipper .224
225 Winchester .224
224 Weatherby Magnum .224
22-250 Remington .224
220 Swift .224
5.6x57mm RWS .224
223 Winchester Super Short Magnum .224
5.6x52mm R (22 Savage High Power) .227
   / Rimfire verses center fire #35
Speaking of rimfire.. how about 5mm rem mag.
Soundguy
   / Rimfire verses center fire #36
I have a .41 rimfire Model 4 1/2, H&R revolver and .38 rimfire Model Dictator, Hopkins & Allen revolver. Try to find ammo for them. :eek:
The last I found of the .41 rf was vintage ammo and around $23 per round!!! Let's just say the one full box of .41 rimfire I have isn't going to get used any time soon.
   / Rimfire verses center fire #37
If you ever run short, here's some more. That would make me cry everytime I pulled the trigger :eek: RimfireCartridge3
   / Rimfire verses center fire #38
Sad isn't it. Cost more to shoot my pistol than my .50BMG rifle. Looks like my ammo has gone up a little. The full box I have is the Pheonix Raised "P". It's selling for $37.50 each now.
   / Rimfire verses center fire #39
What, no 22Magnum in that picture?:)
   / Rimfire verses center fire #40
Just never made it into the picture. :) I shot that picture a couple of years ago for a post on a shooting forum I go to and have been using it ever since. It's a handy comparrison picture for people less informed about firearms.
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
2016 Ford Transit 250 Cargo Van (A55788)
2016 Ford Transit...
Venetian Bronze Aluminum Mailbox Post (A54865)
Venetian Bronze...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
