Rimfire verses center fire
   / Rimfire verses center fire #61
Soundguy said:
Speaking of ammo prices.. at the last show I went to I was buying some .50AE .. about fainted when i saw the price of a 20 rnd box.
Soundguy
Heck, .50AE isn't expensive.... try finding some .440 Corbon. (That's a .50 AE case necked down to 44 cal)..... Have to form my own brass before I can even play...... (It's chambered in an AR15 upper....yes.... 300yd and under set up). I don't know why I went for those odd ball calibers (other odd ball, 6mm PPC USA on an AR upper, free floated, 24" bull barrel w/ a 50 power scope. Making brass for that takes a bit more time....OR.... another AR upper in 357 Sig, yes, the pistol round.)
A 22LR will work for killing the rodents, but it all depends on your range. 22LR is CHEAP to shoot, going to 22 Mag is another story. A 223 Rem (aka 5.56x45) is cheap enough and has enough energy for those little varmints.
   / Rimfire verses center fire #62
czechsonofagun said:
The .357 case is 2 milimeters longer than .38 case - to make sure you will not load .357 to .38 chamber.
Yes, but I mean the cartridge designation.
The .357 mag is longer than a .38spl. It is the same diameter bullet though. I seem to remember reading some where that back in the 1800's when they came up with non-uniform catridge naming, that sometimes they named them for the case dimension.
I have three cases, on .357mag "Blazer" load, another .357mag handload, and a third empty, but sized and deprimed .357mag case. All loaded cases measure 0.375, so I guess you could round that to .38. The sized casing measure .370".
This may be, as someone else mentioned, a size of the barrel lands vs groove too...
   / Rimfire verses center fire #63
Yup, sometimes the name has nothing to do w/ the caliber of the round. Look at .357 Sig and .38 Super (both semi auto pistol rounds). Both use .355" bullets (same as the 9mm Luger/9mm Parabellum).
How about the 44 Mag? It uses .429" bullets......
And don't even get started about if the barrel is measured via the lands or the grooves.....
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
2025 Auger Skid Steer Attachment (A55787)
2025 Auger Skid...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A55787)
2025 GIYI GY-ZWB...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
2006 Pierce Quantum Hale Pumper Fire Truck (A55788)
2006 Pierce...
CASE 90XT SKID STEER (A52705)
CASE 90XT SKID...
