Ballast Rim guard in tires - help with ballast?
   / Rim guard in tires - help with ballast? #11
I have 17.5L - 24 R4 rear tires filled with RG and I believe I run something like 15psi. I took a paint marker and marked the air pressure behind the valve stem. This way, I just look when I check. Really easy.
I also live on steep hills and have not had a problem with the juice leaking or spinning the rim on the tire. Though that does sound like a complete nightmare!
The difference between filled and not filled, I could not tell you. I have always had something in the tires, it is just the way it is. However, RG is way better than the old calcium crap we used to use.
2006 JCB 520 Telehandler (A59213)
2006 JCB 520...
2022 ALLMAND LIGHT TOWER (A58216)
2022 ALLMAND LIGHT...
1999 EZ-GO Golf Cart (A56859)
1999 EZ-GO Golf...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
