Ballast Rim guard in tires - help with ballast?
   / Rim guard in tires - help with ballast? #11
I have 17.5L - 24 R4 rear tires filled with RG and I believe I run something like 15psi. I took a paint marker and marked the air pressure behind the valve stem. This way, I just look when I check. Really easy.
I also live on steep hills and have not had a problem with the juice leaking or spinning the rim on the tire. Though that does sound like a complete nightmare!
The difference between filled and not filled, I could not tell you. I have always had something in the tires, it is just the way it is. However, RG is way better than the old calcium crap we used to use.
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A56858)
2008 Ford F-550...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
LOT: Assorted Hand Tools (A59076)
LOT: Assorted Hand...
