Rim corrosion
/ Rim corrosion #1
V1Rotate
Platinum Member
New Holland TC 29D
I recently bought a used 2003 NH TC-29 with R4 tires. While attempting to check the tire pressure I discovered the rears were filled with what I assume is calcium chloride. I had to drain about four or five gallons out of each tire in order to get the level to the proper point with the valve stem at the 12:00 position. The fluid that came out was sort of milky white but also had a definite brownish-rust color to it. I also noticed some light suface corrosion around the valve stems. I don't know if there are tubes installed, the valve stems are metal with a retaining nut. How concerned should I be?
/ Rim corrosion #2
You can usually tell the difference between a tube and a regular valve stem if you look closely. If you don't have tubes the valve stem will be wider at the base to seal around the wheel. Tube will have more of a straight tapered look and sometimes even grooves to allow air to escape from between the tube and tire as it's being filled.
If you don't have tubes it's going to be messy but if it was me I would drain them, pull the tires off the wheels and then clean them up with a wire wheel, prime and paint them with good quality paint. You'll also find out what shape the inside of the tires are in. Otherwise sooner or later the wheels will rust out and start leaking. At that point you have to buy new ones.
/ Rim corrosion #3
Calcium Chloride will eventually eat through the rims. Tube or not. On my 1964 135 Massey with tubes it took 40 years before the Calcium Chloride damaged the rims to the point that I had take the tires off, fill weld the damaged areas, and grind them smooth.
/ Rim corrosion #4
Not clear on why you had to drain the liquid out, unless someone bumped the pressure too high after they were loaded?
/ Rim corrosion #5
I would be conerned
/ Rim corrosion #6
You do not have tubes.
__________________
Don
In the case of tube equipped for liquid fill you cannot tell this for sure w/o taking a pretty close look at the nut holding the valve stem to the rim. Is it clamping it tight using a washer and nut or just holding it in place? Usually you can wiggle the tube stems.
larry
/ Rim corrosion
It is my understanding that tires should only be filled to about 75% capacity which is to the top of the rim with the valve at the 12:00 position. (correct me if I'm wrong) These tires were definitly overfilled, so I wanted to not only set the proper level but also make sure that both tires were equal.
/ Rim corrosion #8
I have also read that but I have been told some people like to fill them a little more so the rim is always in fluid to help reduce oxidation/ corrosion.
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2022 EZ-GO ELITE...
2025 Kivel 48in Fork and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
