rigid insulation and vapor barriers
   / rigid insulation and vapor barriers #1
randy41
Linden VA
this is a bit confusing to me. there are generally 2 kinds of rigid insulation. there's eps and polyisocyanurate. how do they deal with moisture? is eps unaffected and polyiso needs a vapor barrier? is the covering on polyiso a vapor barrier?
i am building a walk in cooler and researching insulation options. the rigid insulation will be used in conjunction with roxul. i read 2 articles online and they are contradictory.
   / rigid insulation and vapor barriers #2
The foil insulation on the poly is a vapor barrier. It is best to foil tape any seams. EPS will let vapor pass through.
Ken
17101 (A55787)
17101 (A55787)
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
Jacobsen three wheeler mower (A56857)
Jacobsen three...
LINCOLN 225 ARC WELDER (A58374)
LINCOLN 225 ARC...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2020 DRAGON ESP...
