rigid insulation and vapor barriers
   / rigid insulation and vapor barriers #1
randy41
Linden VA
this is a bit confusing to me. there are generally 2 kinds of rigid insulation. there's eps and polyisocyanurate. how do they deal with moisture? is eps unaffected and polyiso needs a vapor barrier? is the covering on polyiso a vapor barrier?
i am building a walk in cooler and researching insulation options. the rigid insulation will be used in conjunction with roxul. i read 2 articles online and they are contradictory.
   / rigid insulation and vapor barriers #2
The foil insulation on the poly is a vapor barrier. It is best to foil tape any seams. EPS will let vapor pass through.
Ken
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2021 Caterpillar XQ125 125kVA Towable Diesel Generator (A55973)
2021 Caterpillar...
2008 International Bucket Truck (A55973)
2008 International...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
