rigid insulation and vapor barriers
   / rigid insulation and vapor barriers #1
randy41
Veteran Member
Linden VA
this is a bit confusing to me. there are generally 2 kinds of rigid insulation. there's eps and polyisocyanurate. how do they deal with moisture? is eps unaffected and polyiso needs a vapor barrier? is the covering on polyiso a vapor barrier?
i am building a walk in cooler and researching insulation options. the rigid insulation will be used in conjunction with roxul. i read 2 articles online and they are contradictory.
   / rigid insulation and vapor barriers #2
The foil insulation on the poly is a vapor barrier. It is best to foil tape any seams. EPS will let vapor pass through.
Ken
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A57453)
2016 Volvo VNL...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2022 Harley Davidson Electraglide (A55973)
2022 Harley...
