Righty loosey
/ Righty loosey #1
chas0218
Southern Tier N.Y.
LS MT235E
So I just came up on my 200 hour service and I start looking things over checking bolt tightness and other things. I noticed my rear backhoe subframe bolts look loose. I figure no big deal as I haven't had the hoe on in a while. I grab my torque wrench and set it to 60lbs. first working up to 100 ft.lbs. well once I hit 80 I had 1 let loose. I can't remember now what the max torque was but I think it was around 120 ft. lbs.
Now what the heck am I going to do? I needed the hoe this weekend now I have a stripped bolt and out of the bumper to bumper warranty.
/ Righty loosey #2
How much of the bolt is sticking out? Any?
You can spot weld a wash and nut to the broken bolt and back it out. The heat from the weld usually heats it up enough to make it loose.
If no welder then:
Harbor Freight or Amazon overnight.
Center punch
Left hand twist drill bits
Drill it out and use an extractor to back it out.
Hope that works for you.
  • Good Post
Reactions: JJT
/ Righty loosey
If no welder then:
Center punch
Well it isn't broken off just no threads left in the casting of the tractor for the bolt to engage. I need to see if the bolt hole is deeper and maybe I can get away with a longer bolt. Really sucks as I don't have many hours on the tractor.
/ Righty loosey #4
Is there thick enough casting to drill it out and put in a heli-coil?
/ Righty loosey #5
Can you use a bottoming tap and re-thread it one size up...ream the hole in the hoe and get a new bolt...
/ Righty loosey
Looks like there is a lot more thread deeper in the hole. I got a longer bolt and added a couple washers. Tightened it up to 100 ft.lbs. without issues but don't think i want to go to the 150. Any thoughts on going to the 150 ft. Lbs.? I dont think it is needed with the loctite.
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-636...
Wood Fence Post (A62613)
Wood Fence Post...
New/Unused Electric Winch (A65583)
New/Unused...
