Rhino rotary cutter minus 1 blade
   / Rhino rotary cutter minus 1 blade #1
corwin5
Westminster, Maryland
TC29D
Folks,
This past weekend, I was using my LT5 rotary cutter in some dense weeds and unfortunately came upon a "hidden" tree stump.
The tractor immediately stalled and after re-starting, the LT5 ran with a distinct vibration.
Thinking that I had "dinged" one of the 3 blades pretty severely to put the cutter out of balance so much, I looked under and found that one of the blades actually came free from the attachment point; it appears as if the bolt attaching the blade to the rotary piece actually pulled through and is now distorted so that, even if I could locate the blade (no luck yet), the hole to attach the blade is warped and wouldn't accept the blade, as is.
The cutter is less than a year old and I've been very pleased ( up to this point), but I would have expected the shear pin to have broken and relieved some of the apparent stress on the blade attachment. I'm sure that this isn't a warranty item, but I certainly would have expected the shear pin to alleviate some of this type of damage.
Anyone have a similar incident? Does anyone have acces to a parts list for a Rhino LT5 cutter? Rhino has discontinued in favor of a new product line and I'm having problems locating a repair manual.
Thanks in advance.
   / Rhino rotary cutter minus 1 blade #2
I have a Rhino LT5 cutter, but mine only has 2 blades. I have the manual with parts list, I will post the 2 pages concerning that section of the mower.
Here is pic 1
   / Rhino rotary cutter minus 1 blade #3
Here is Pic 2, I hope this helps out.
Ed,
Much thanks for the diagrams.
I have done a little more research and chatted with the folks at Rhino. It appears as if the replacement shear pins supplied may not be a grade 2 and are a 5 or 8.
While I'm not pleased at this possibility, it gives me a better confidence that this wasn't a manufacturing defect. Are you generally pleased with your LT5?
   / Rhino rotary cutter minus 1 blade #5
The only problem I've had was one time when I sheared a bolt, the shaft slipped back towards the gear box and I had a heck of a time getting it to slide back foward over the remnants of the shorn bolt. You can get all the details of that adventure in this </font color=blue>thread. I sheared quite a few bolts when I first got it and was figuring out how to set the mowing height, but other than that it has performed quite well.
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53472)
2019 Energreen EVO...
1998 Blaw-Knox PF 150 Paver (A52384)
1998 Blaw-Knox PF...
Miles read : 112,969 (A50323)
Miles read ...
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
2010 TAKEUCHI TB235 EXCAVATOR (A51246)
2010 TAKEUCHI...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
