Rhino rotary cutter minus 1 blade
   / Rhino rotary cutter minus 1 blade #1
corwin5
Westminster, Maryland
TC29D
Folks,
This past weekend, I was using my LT5 rotary cutter in some dense weeds and unfortunately came upon a "hidden" tree stump.
The tractor immediately stalled and after re-starting, the LT5 ran with a distinct vibration.
Thinking that I had "dinged" one of the 3 blades pretty severely to put the cutter out of balance so much, I looked under and found that one of the blades actually came free from the attachment point; it appears as if the bolt attaching the blade to the rotary piece actually pulled through and is now distorted so that, even if I could locate the blade (no luck yet), the hole to attach the blade is warped and wouldn't accept the blade, as is.
The cutter is less than a year old and I've been very pleased ( up to this point), but I would have expected the shear pin to have broken and relieved some of the apparent stress on the blade attachment. I'm sure that this isn't a warranty item, but I certainly would have expected the shear pin to alleviate some of this type of damage.
Anyone have a similar incident? Does anyone have acces to a parts list for a Rhino LT5 cutter? Rhino has discontinued in favor of a new product line and I'm having problems locating a repair manual.
Thanks in advance.
   / Rhino rotary cutter minus 1 blade #2
I have a Rhino LT5 cutter, but mine only has 2 blades. I have the manual with parts list, I will post the 2 pages concerning that section of the mower.
Here is pic 1
   / Rhino rotary cutter minus 1 blade #3
Here is Pic 2, I hope this helps out.
Ed,
Much thanks for the diagrams.
I have done a little more research and chatted with the folks at Rhino. It appears as if the replacement shear pins supplied may not be a grade 2 and are a 5 or 8.
While I'm not pleased at this possibility, it gives me a better confidence that this wasn't a manufacturing defect. Are you generally pleased with your LT5?
   / Rhino rotary cutter minus 1 blade #5
The only problem I've had was one time when I sheared a bolt, the shaft slipped back towards the gear box and I had a heck of a time getting it to slide back foward over the remnants of the shorn bolt. You can get all the details of that adventure in this </font color=blue>thread. I sheared quite a few bolts when I first got it and was figuring out how to set the mowing height, but other than that it has performed quite well.
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
2023 JACTO ARBUS-1000 LOT IDENTIFIER 66 (A53084)
2023 JACTO...
JLG 36AM-DC VERTICAL ELECTRIC PUSH AROUND MANLIFT (A51247)
JLG 36AM-DC...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
