Backhoe Rhino backhoe?
   / Rhino backhoe? #1
tman1020
north west indiana
Bobcat ct225 and Bad Boy zero turn
Anyone out there have a rhino 75C backhoe. I have the bobcat version of the CK 27 and would like to put a backhoe on the back of it. I'm wanting to know if you have to remove the three-point linkage in order to install the subframe mount backhoe. Also if anyone has any experience with the rhinos good experiences or bad would appreciate hearing about them. Thanks.
   / Rhino backhoe?
Also was wondering if anyone has tried the 8TB other tractor.
   / Rhino backhoe? #3
I don't have a 75. But I run a Rhino 85 on my DK 35 and the 3 point linkage can be left on.
   / Rhino backhoe?
Thank you DKvince. I'm thinking about trying to put that TBH8 on my CT 225. I know it's one size larger than they recommend. What's your opinion on it does your tractor Handle the eight no problem do you think it would be okay on a slightly smaller frame?
   / Rhino backhoe? #5
My Rhino 85 is an 8 1/2' backhoe. My DK 35 handles it with no problem.
I'm not familiar enough with the CT or CK series to say how an 8 would work.
   / Rhino backhoe?
Thanks again for the info.
   / Rhino backhoe? #7
I have a 8tb on my ct335 bobcat tractor, my 3 point hitch was removed to accept the subframe and backhoe, not sure it can be left on but I don't think it would leave much room. Overall I am very pleased with the hoe, she's very well built, the subframe ties into the tractor very well. The controls are very comfortable and responsive for a small hoe. I would recommend trying to find a 8tb if possible. I have owned a woods 7.5 and it was also a nice hoe however it does not compare to the bobcat 8tb.
   / Rhino backhoe?
Thanks again i'm still hunting having a hard time finding the bobcat version may have to go with the rhino version. I just hope that I can leave the three-point linkage on. I also would like for the subframe to stay on the tractor when I remove the backhoe wonder how hard that will be.
   / Rhino backhoe? #9
The sub-frame is bolted to the backhoe and clipped with pins to the tractor. Much easier to take it on & off with the sub-frame. I think, not sure, the sub-frame sticks out the rear some and might interfere with using 3 point attachments. If the sub-frame is problem for storing the backhoe, remove all 1 bolt on each side and swing the frame vertical and strap to the hoe.
   / Rhino backhoe? #10
I think if you want the subframe to remain on the tractor you need to go with Woods with the 4 point type frame. But I believe the 3 point must be removed for this style backhoe to be installed.
The Bobcat/Rhino subframes are attached to the backhoe and come off with the hoe.
2015 JLG Triple-L Flatbed T/A Trailer (A50323)
2015 JLG Triple-L...
City of Tampa (1709) VIN: 1FTYR10U67PA38092,**Title MUST be transferred into buyer's name INCLUDING (A51692)
City of Tampa...
John Deere 4420 Combine (RUNS) (A50774)
John Deere 4420...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
