RHINO 344 WOES
/ RHINO 344 WOES #1
bearlythere
OK, thanks Norm for the reply. At the risk of sounding ignorant, maybe I should just ask the question: what are the typical steps involved with changing out sediment bowl assembly on bottom of fuel tank...........I really could use some help....manual is in broken chinenglish, can't find online help, and don't figure that its outside my abilities. thanks
/ RHINO 344 WOES #2
You usually just open the drain and let some out to flush the accumulated crud out. If it has no drain, you have to close the fuel feed from the tank and usually unscrew the bowl. Dump it and wipe clean.
Was the document in Chinglish or Engleese?
jb
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Pat's QH and hydraulic top-link.
Pat's QH and...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
Great Dane Van Trailer (A63118)
Great Dane Van...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
