RFM
kcook
Platinum Member
MI
Cub Lawn Tractor
Looking for a good RFM model, make, size, and Rear Dischardge or Flail? Price is important!! For a CK20S Hydro.
Thanks
KC
I have a Bush Hog RDTH-60 and paid $1200 for it new last year on a dealer close out. Could not be happier with it. If you have several acres to cut you might want a 6' model. Get a heavy duty good brand name one because it will be with you forever. The bargain models do not cut as well as I tried about half dozen before I decided on my Bush Hog. The five and six hundred models just do not cut the same and I do not imagine their durability is much either.
/ RFM
Will be cutting 2 to 3 acres when it all done.
KC
I'm not particularly partial to any brand as long as it's rear discharge. I have a 7ft. Kioti that I believe is a rebadged Italian unit. Otherwise, I guess if I was buying a new one now I would go with Landpride only because I have other implements by them and they seem sturdy. Befco would be my second choice.
KC
A 5' RFM would do fine on that size lot. If you had 4 or five acres you could tell the difference in a 5' and a 6'. Of course if you do not have a lot of trees and got a deal on a 6', I would still go for it. Don't much care what brand, just get a good one.
Thanks
KC
I agree with daBear. 5' would be enough for this size lot. Rear discharge is the way to go now. I now have a Woods PRD7200 72" rear discharge that of the three 72" RFM mowers I have owned is by far the best. In my experience Land Pride, Bush hog, and Woods make the best mowers. These are high dollar mowers. I did try to go cheap years ago with a 72" Caroni. I'll never do that again.
I bought a Land Pride 7ft rear finish mower with a side discharge used for $600 a few years ago. It had two flat tires and all four tires needed replacing. I upgraded to solid tires, which was pricey, but worth it. I also replaced all three blades and the belt.
One thing that I like about Land Pride is they are serviced by all Kubota dealers now. I just walk in, order what I need and know that it's on it's way. Great support and service!!!
Eddie
Eddie
That I didn't know. Good info, Thanks.
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
2014 Chevrolet Traverse (A62613)
2014 Chevrolet...
Skid Steer Mounted Bush Hog (A62613)
Skid Steer Mounted...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
