RFM Operation
/ RFM Operation #1
NewToy
Ohio
'05 Farmtrac 270DTC
I have a 60" LandPride side discharge finish mower. In the owner's manual they mention not to back up while mowing. I was wondering if this was a safety thing or if there was potential to damage the thing by backing up?
Thanks for the help.
John
/ RFM Operation #2
I'd contact Land Pride with your question...
I operate in reverse with my Befco mower quite frequently. Never had any problems.
I'd be interested in Land pride's response.
/ RFM Operation #4
Do it all the time with my 72"KK.
Nothing in my manual that says not to..
However, the cut is not as nice when backing, as it
can't discharge the grass as easily.
/ RFM Operation #5
It's gotta be a safety thing. That's probably why a lot of newer riding mowers won't cut in reverse. I read where some kick the pto out and if I don't have an override button pushed on my bota lawn tractor, the engine will stall if I back up with the pto engaged.
Maybe they figure a lot of tractor operators are like little old ladies... only without the rear view mirror. /forums/images/graemlins/tongue.gif
/ RFM Operation #6
I am also guilty as charged we have mowed while backing to trim under trees and around our pond. Think it's more of a safety issue myself.
/ RFM Operation #7
I've been meaning to ask the same question. I bought a LandPride 72" RFM this Spring, but mine is a rear discharge. I thought it had something to do with not wanting to clog things up by mowing in the direction of the discharge, but if they have the same warning for side-discharge, I would say its just a safety issue--not being able to see as clearly what you are mowing over. They also said in my book not to make sharp turns, but I don't see how you can effectively use the product to mow around trees and typical obstructions without making sharp turns. The mower certainly seems rugged enough and the wheels turn freely enough to avoid any damage. I presume that its a safety concern to do with having a mower sticking out so far where it can easily swing into a building or tree if you aren't paying attention. Assuming you keep your brain engaged, and do these maneuvers with as much care as you should always exercise while mowing, I don't see what damage you can do to the mower or tractor.
/ RFM Operation
I'm with you guy's, I'm convinced it is a safety concern. Coincidentally there was a 2 year old girl that was backed over by a tractor after I posted this. The details were sketchy in our local paper, basically the little girl was running behind the mower playing and the guy backed right over her. She was seriously injured but was expected to live. I guess I'll continue to back up, but after a good look around first.
I cleaned all the funk from under the mower today. I was hosing and putty knifin' for an hour or so, all cleaned up and greased for the winter. Hopefully I'm done mowing for the year.
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A64557)
2020 23 Ft...
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
72in. Fork Extension (A64553)
72in. Fork...
2021 JOHN DEERE 410E SERIES II OFF ROAD DUMP TRUCK (A65053)
2021 JOHN DEERE...
2014 KENWORTH T370 ROAD TRACTOR (A65054)
2014 KENWORTH T370...
2025 Mini Bucket Excavator Attachment (A64553)
2025 Mini Bucket...
