Reverser for snowblower
/ Reverser for snowblower #1
LHoyer
Danbury,WI
Kubota B7100
Current project is to mount an Ariens 2-stage snowblower to the front of my Kubota B-7100. The Kubota front PTO spins CW and the Ariens needs CCW, so I will be building a v-belt reverser and speeding the drive up slightly (27-2800 rpm to about 3200 rpm). On the attached drawing (not to scale), where should the tensioner be placed? Position A or B. I understand the tensioner should be on the slack side, so is position B correct? I will be using a double sided, AA-series v-belt, and will have about 240 degrees of wrap on the driven pulley.
/ Reverser for snowblower #2
B side will be pulling so A side would the slack side.
Thanks everyone. Sincerely appreciate the responses.
/ Reverser for snowblower #5
Your routing of the belts will work. However, it puts double the torque on the right side idler and it's bearings. If I can get a diagram to attach you will see that the tension side of the belt goes directly from the drive pulley to the driven pulley. All the idlers do is take up the slack.CCI06082021.jpg
/ Reverser for snowblower #6
Your routing of the belts will work. However, it puts double the torque on the right side idler and it's bearings. If I can get a diagram to attach you will see that the tension side of the belt goes directly from the drive pulley to the driven pulley. All the idlers do is take up the slack.View attachment 701784
His belt routing has contact with almost half the pulley where yours is quite a bit less which would be more prone to slipping.
/ Reverser for snowblower #7
By moving the left idler pulley up the belt wrap can be increased, I suppose I should have completely redrawn the diagram. If he wants to eliminate slippage completely roller chain would do the job.
/ Reverser for snowblower #8
Did mine the same way but with chain, running at 540. I just use the idlers for chain tension.
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2017 Case CX145D (A62177)
2017 Case CX145D...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
