Reuse hydraulic hose?
   / Reuse hydraulic hose? #1
TRR
Central Texas
Kubota L235
If a hose has been placed in service and has had oil run thru it, if it needs to be made shorter can the end be cut off and a new one put on, or does the oil make it to slippery for the fitting to hold onto, meaning I'd need to replace the hose.
   / Reuse hydraulic hose? #2
If the hose is still usable , not cracked, no wire showing, and no problems before, then you can have new fittings installed.
   / Reuse hydraulic hose? #3
It should be OK. As long as the wire braid is not falling apart from bending. The standard construction cross section for hose is 100-R1. which is a inner hose and a wire braid covered by a outer rubber cover. The crimp fitting grabs the inner hose and the wire braid and cover so it's a pretty strong assembly. I've cut up long hoses and made shorter hoses many times.
Edit
I had my SAE numbers incorrect from dealing with so much 100R7 hose from Synflex in the past. I meant 100R1 which is the garden variety hydraulic hose construction for compact tractors.
   / Reuse hydraulic hose? #4
shaley said:
It should be OK. As long as the wire braid is not falling apart from bending. The standard construction cross section for hose is 100-R7. which is a inner hose and a wire braid covered by a outer rubber cover. The crimp fitting grabs the inner hose and the wire braid and cover so it's a pretty stong assembly. I've cut up long hoses and made shorter hoses many times.
Huh??
   / Reuse hydraulic hose? #5
I will assume this is a new hose? If so-and you go back to the same shop you should have no trouble getting them to shorten it up a bit. If it's an old ratty hose then forget about it.
   / Reuse hydraulic hose? #7
I've had a new fitting put on a used but good condition hose. The guys in the hydraulic hose shop didn't blink when I asked so I don't believe it is uncommon.
   / Reuse hydraulic hose? #8
Just curious how many of you guys turn down business because you don't have the same brand fitting/hoses? I think that most people take a hose in the hyd shop and tell them to fix it, and they do it. I have yet to hear one of them say something like this, I am awful sorry but I can not match up hose to fitting, I am forbidden to mix and match.
Do you all really think the guy using the hose even cares about matching brands? He wants it fixed. Time is money, bottom line.
   / Reuse hydraulic hose? #9
Actually, SAE 100R7 hose does not contain wire or rubber. SAE 100R7 is a thermoplastic (nylon) hose with braided fiber reinforcement. It has a maximum working pressure similar to SAE 100R1AT (single wire braid). A heavier version, SAE 100R8 is available for higher pressure applications.
Because SAE 100R7 and 100R8 hoses do not contain metal wire, they will not conduct electricity as well as most other hydraulic hoses. They are often found on bucket trucks and man-lifts with an orange cover on the hose to identify it as nonconductive. This is a very important safety feature for utility trucks and other equipment that will be used in close proximity to electrical lines.
Thermoplastic is also used quite bit in sewer cleaning equipment, because it's smooth outer cover is easier to clean and slides more easily through pipes and drains.
We don't find a lot of thermoplastic hose on farm equipment. It's more expensive than wire-reinforced hose, and the benefits it offers - nonconductivity and a smooth outer cover - don't really apply to someone driving a tractor or a harvester.
Getting back to the original question,
If the hose is in good shape, you can cut it shorter and put on a new fitting, but I would take some extra care in cleaning it first. Cutting hose creates a lot of dust, and oil is a dust magnet. Hydraulic fluid residue inside of your hose will grab hold of that dust, which will eventually wind up as debris inside your hydraulic system. Clean the hose before and after you cut it to get the best results.
Your mileage may vary, but if keeping your hydraulic fluid clean is important to you, keep this in mind whenever you consider re-using a used hose.
2010 GMC Acadia SL SUV (A50324)
2010 GMC Acadia SL...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
Barn Wood Planter Box (A50515)
Barn Wood Planter...
2011 Ford F350 Service Body (A47384)
2011 Ford F350...
