Returning batteries for warranty claim
   / Returning batteries for warranty claim #11
If my tractor is showing 13.4+ on voltmeter and I have no trouble light on as stated, why would it be alternator?
Your batteries are only 5-6 months old. They still have the CCA that they're rated for after they're charged. So you know the batteries are good.
The next step in troubleshooting would be to check all your connections again, and have your alternator load tested. It should put out at least 13.8 volts. Closer to 14V.
They’re rated for 900CCA and currently have 690-700CCA
Yes, I know that.
It is putting out high 13.4 and more volts. with engine running.I don’t consider that a sign of alternator failure.
   / Returning batteries for warranty claim #15
Big difference in 700 CCA and 900 CCA , I had a tractor battery that started that and I could slow charge it overnight and get a few days out of it but then right back to failing to start the tractor, it was out of warranty so I replaced it and not another problem for the last 2 years and there wasn't anything wrong with my alternator either.
   / Returning batteries for warranty claim #16
Get the alternator tested by a pro.
I learned one of the three(?) alternator diodes had failed, after putting up with dim headlights on the elderly Subaru over a couple of years. It always started readily so I hadn't suspected the charging system.
I expect your charging voltage should be higher.
   / Returning batteries for warranty claim #17
Does NAPA have new batteries in stock? If yes have them check the CCA of new vs your batteries. Should provide a good basis for how much they have decayed during your use.
   / Returning batteries for warranty claim #18
For what its worth a typical alternator working properly puts out it best amperage at 14 (plus ) volts.. Anything less you are not getting enough "over voltage" to properly recharge battery....
IF you are not getting batteries up to 14 plus volts after considerable run time, I suspect bad alternator or your voltmeter is lying to you.... This is if dealer test find nothing wrong with batteries.....
Todays lead acid batteries (flooded cell) and not near the quality as they were years ago.... I have found getting AGM (Absorbent Glass Mat) batteries not to much more expensive but a little more reliable....
   / Returning batteries for warranty claim #19
I have live data readers on dash of my trucks that read 14+ after plug heat and crank then progressively drop to as low as 13v on long daytime trips. Retailer has the right to put battery on charge before making a warranty decision but high volume outlets should have instruments to test without long charge. If possible I put batteries on smart charger to see if it will reach at least 12.5 before taking in for warranty. Since I began using Deltran Tenders several years ago 90% of batteries last well beyond warranty. When warranty has expired but battery still performs I replace it and put it on something non-critical. Both batteries on a Ford truck were replaced after 4 years and continued to do duty until one failed at 12 years old. Since the day a kid at parts store load tested my battery while truck was running I'm particular who gets under the hood.
   / Returning batteries for warranty claim #20
Legend batteries usually test above CCA when new.
Decent East Penn/Deka product.
I would also like to see about 14 volts fairly soon after starting.
A fully charged 12 volt battery will show 12.6 volts at rest-2.1 volts per cell/6 cells.
Perhaps a winters worth of use undercharging by a bit has taken some of the life out of them?
Good Luck!
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2013 Audi A6 AWD Sedan (A56859)
2013 Audi A6 AWD...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
BIN PARTS, SWEEP AUGER & ELECTRIC MOTOR (A52708)
BIN PARTS, SWEEP...
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
